Data visualization in Vectorworks is a game changer for your BIM workflows! Learn how to implement it and transform how you approach design decisions in your BIM process.
Data visualization turns data into knowledge, helping you make more informed decisions faster. It puts the data embedded in your objects into a visual, graphical context, applying it directly through your models and drawings. Just as your models help you conceptualize your project’s layout and design, data visualization lets you picture your “non-design” elements.
Data visualization gives you an aggregate, dynamic view that displays the graphical attributes of objects (color, fill, pen, etc.) based on various data, whether general or specific, according to function, object type, value or range of values, or any other attached record parameters that you specify. Think of it as a graphical or visual report.
The same live BIM model and the data it contains can be presented in numerous ways simultaneously - and it can be used both within the design space during your design process AND on Sheets as a presentation tool.
Examples of data visualizations you can perform in your BIM models include:
Data visualizations can be saved and applied to design layers and to viewports on a sheet layer. When a visualization is modified, your edits apply globally and instantly!
Additionally, a data visualization can be applied to perform quality checks to ensure that changes have been made correctly.
Since Data Visualization can easily be turned on from the View bar, it’s simple for you and your colleagues to display the drawing with either a data visualization or the object attributes.
Multiple data visualizations can be selected for display at one time, meaning you can quickly create sophisticated presentations that used to take you hours or days to produce.
In addition to being saved to a current file, data visualizations can also be saved in the user folder and a workgroup folder. This means that they can be used in other files and by other people in your organization.
Worksheets have image functions that can apply a visualization to an object image by referring to a saved visualization or to a viewport’s applied visualization set.
To create a new data visualization in Vectorworks, locate the Data Visualization menu. This menu is only available from the View bar when your design layer is the active layer. Or, you can create a data visualization from the Manage Data Visualizations dialog.
From there, follow these steps:
If you create a new data visualization from the Object Info palette of a selected viewport, it’s automatically applied to that viewport and any other selected viewports as well as in the Data Visualization menu.
To learn more about the data difference, check out our first story in the series, “The Data Difference | 3 Ways to Maximize Your Data Use for BIM.” The story covers the power of the Object Info palette, the Data Manager, and dynamic data assignment.
Click below to give it a read:
